12-string FB radius?
http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=9825
Author:  Josh H [ Thu Dec 14, 2006 1:42 am ]
I use a straight 16 on my 6-strings. What do you guys use on your 12-strings? Is there a standard radius that factories use?
joshJosh H39065.4101273148
Author:  Michael Dale Payne [ Thu Dec 14, 2006 1:57 am ]
I have used 20 and 16 both
Author:  Pwoolson [ Thu Dec 14, 2006 1:59 am ]
12 to 20 compound. which makes 16 at the 12th fret. They've played very well. Pwoolson39065.4169675926
Author:  Josh H [ Thu Dec 14, 2006 9:59 am ]
Thanks guys,
I only have a 16 radius block so I will probably give that a try. I'm curious to know what the factories are using. I will have to do a little more research.
Author:  peterm [ Thu Dec 14, 2006 10:42 am ]
Josh, i think 16" is the most common even for 12 strings...
Author:  KiwiCraig [ Thu Dec 14, 2006 11:12 pm ]
Hi Josh,
           I'm building a twelve as well. I've decided on 20" because of the neck width .
Regards Craig
Author:  Michael Dale Payne [ Fri Dec 15, 2006 1:49 am ]
I just checked a Martin J21-16 it is 16" radius
Author:  crazymanmichael [ Fri Dec 15, 2006 3:15 am ]
martin guild and taylor all use 16" on current offerings.
many older martins were compound 16-20"ish. i have also seen a few old 12's with a flat board. barre chords were not being played much on 12's then i guess.
